Guest viewing is limited
Discuss Do these tiles need sealing or similar? in the Canada Tile Advice area at TilersForums.com.
stott
Hi everyone, just a quick question, hopefully straightforward.
Do these need sealing as per the advice on the Topps site?: Chic Craquele Tiles | Topps Tiles
I'm using the brick shaped ones in a shower, tanked with WP1 and using bal rapidset flex and norcross grout as I had good results with these in the other bathroom.
They are glazed ceramic with a cracked finish.
Any advice appreciated
Cheers
Turkish tiler
I would use Fila Polished Porcelain Protector or lithofin kf stainstop before grout if you cut any on wet saw need to seal them day before and dont draw cutting lines with black pencil before you cut them in wet saw it will soak under glaze
make sure you have got very clean water and very clean sponge any dirt will go under glaze before sealing
Reply to Do these tiles need sealing or similar? in the Canada Tile Advice area at TilersForums.com
Hello, I have some lovely Mexican terracotta tiles (glazed on one side only) which are meant...
Hopefully a very easy quesion(s) for someone who knows ? Tiles and one wall and painted, white...
benchwarmer
Need some advice please on sealing Slc. Not sure if I'm in the right place for this but worth a...
hmtiling
H
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
