Discuss Do you believe this R-Value in the Australia Tiling Forum area at TilersForums.com.
V
vrytir
Hi guys, just about to install underfloor heating and trying to get insulation boards. I found 6mm thick versa backer board http://www.building-boards.co.uk/tile-backer-board/#.U5WCKnZ4CDg which has high R-Value 1.25 and it is only 6mm thick. Would you believe this? As 10mm warmup insulation board has u-value 2.7 (r-value 0.37), marmox boards 10mm has R-value 0.28 and Kingspan Thermafloor TF70 20mm has R-value 0.9.
So should I believe clam that 6mm has rvalue 1.25?
What insulation board would you recommend. Installing on to concrete and then laying oak engineered flooring.
Reply to Do you believe this R-Value in the Australia Tiling Forum area at TilersForums.com
Hey, this is my first time attempting to tile in my first home. Did a bunch of research last...
Hi, need a bit of advise for a up coming job. It is a large kitchen floor, timber floor boards...
Hi all, I'm new to the forum so please forgive any silly questions, I've taken on rather a big...
8K
E
Hi there, I wonder if you guys can give me some advice please? Currently my kitchen floor...
27K
Sarah sparky
Ok, After 18 months, I am going to remove the plastic sheeting around the bath/shower and tackle...
blue_max
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
