peckers
Tiles are getting bigger and harder and we all buy diamond blades to cut them with, and bigger and stronger manual cutters too!
And im sure 99% of us tilers have diamond drill bits in the van/car now these bits aren't cheap and even though you can buy some great drill bits that are value for money like 365 drills or you buy something like the marconist 850 set eventually you have to replace these bits!
So do you bite the bullet and cover the cost of these yourselves or do you charge for drilling these holes for pipes taps showers led lights etc? and if you do charge how much per hole? and do you show it on your estimate/quote? or hide it in the total price?
today i have been tiling a bathroom which has porcelain on the walls and floors
it has a wall hung pan and cistern push button so thats x3 holes here done and a diamond disc was used for cutting out the waste hole etc as it cant be seen!
hot and cold feed for sink x2 holes
waste for sink x1 hole
flow and return for heated towel rail x2 holes
cut out for shower mixer valve
and feed for water to go up shower hose x1 hole
in total 9 holes drilled using diamond core bits
2x cut outs useing diamond disc in angle grinder
thats money out of my pocket when i need to replace the bits
