Stuart Williams
I've had a search and can't find the answer probably because it's obvious but want to check anyway.
Stripped the old downstairs wet room and removed all the plaster as it was damaged back to the sand and cement coat. After leveling the floor I'll be installing a tray and screen.
My question is, I've been given tanking solution to paint on by a mate, do i actually need to paint the two walls the shower is going on? I'm tiling straight onto the sand and cement coat with a cement based adhesive and grout and a coat of SPD primer.
Best image I could find attached, you can make out the corner.
