doing a bathroom floor need help
steve84
hi am doing my sisters floor will i take the toilte system out its a sammy modile is that ok to do and wat ply wood will i use or cement boared better heeers
How big's the floor Steve? I'm assuming it's an additional bathroom because of the saniflow so shouldn't be too big in which case a 6mm cement board such as hardi or No More Ply should do the job. If you're fixing it onto timber make sure you use the right kind of adhesive as well as screwing.
Cement boards offer less flex than plywood and don't disintegrate with moisture so are a much better option, but if you wanted to stick to plywood then you should think about 15mm to be safe, screw fixed at 30cm centres.
Good luck with the job mate - take your time and keep your cool.
