Discuss don't use unibond? in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
BAL Bond SBR
A waterbased polymer with a wide variety of uses in the construction industry, particularly as an admixture and bonding agent for cement and concrete applications. Once cured, the polymer is water and frost resistant. BAL BOND SBR can be used as a slurry coat when mixed with hydraulic cement or gypsum plaster, as a multi-purpose admixture for cement:sand mortars, concrete and gypsum plaster; as a brush applied primer, sealer or dustproofer.
Suitable for use on cement:sand screeds, toppings or renderings, plastering, waterproofing, bonding, concrete repair, priming and sealing.
Reply to don't use unibond? in the British & UK Tiling Forum area at TilersForums.com
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
don't use unibond?
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
