Discuss dot and dabbing platerboard on breeze block in the UK Tiling Forum area at TilersForums.com.
coming from a plasterer thats weird whitebeam,ive always primed internal blockwork(if its old and dusty).There should be no need to prime any blocks, if there dusty dampen the wall area with water where your dabs of adhesive are going....don't use pva if you decide to prime..
everything whats said on this forum about priming ect ect before tiling,surely the weight of plasterboard on dusty blockwork would be a issue,just saying,not bitching mate :smilewinkgrin:
know what you are saying,but i did a 4 1/2 year apprenticeship trained by very experienced plasterers(with probably over 300y experience between them) ,always got told to prime dusty walls with PVA,internally and use exterior PVA on exterior rendering,each to his own i supposeI did the Dri Walling course at Brittish Gypsum and was taught only to wet/dampen dusty and high suction areas that were about to sheeted using the dot n dab method with Dri Wall adhesive.....
Created on iPhone.....
Reply to dot and dabbing platerboard on breeze block in the UK Tiling Forum area at TilersForums.com
