Discuss Dot & Dab plasterboard in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
I see a lot of comments about Dot & Dab-ing plasterboard. Please excuse my ignorance, I am just a mere accountant, but is this primarily relevant brick or block built walls?
Up here in Scotland almost all of the new houses built up here in the last decade or 3 have been of timber frame construction and interior walls are more or less all stud partition. Am I correct in the assumption that to replace plasterboard with this construction requires complete removal of old board and then new boards screwed to the studs, then taped and filled ?
The budding joiner - Grumpy
GazTech
Absolutely Grumps..In bathrooms especially it is now better to replace damaged plasterboard with Backer boards,if onto studwork then screwfix firmly,if onto block or brick then dot & dab.Not only are backers better for in wet areas as in not rotting,they will also bear more weight for tiling.
grumpygrouter
Another question then, I am lined up to do a repair to a shower cubicle. The step into the cubicle was originally a piece of timber that has been tiled over. As you can guess, the timber has gone rotten and tiles are now falling off. What would be the best way of "rebuilding" the step for retiling. I was thinking of strips of backerboard layered up to make a step and then tile that but it seems a bit "heath robinson". Any ideas of how to go about this?
Grumpy
GazTech
Grumpy
If you remove all timber and clean the area up,you can build the step using thermalite or breeze blocks.Bedded into flexi adh...with joints between filled with flex adh.Very easy to cut thermo blocks with old panel or rip saw,either tile directly onto step or backer board it prior to tiling.....nice and solid mate....Gaz
Reply to Dot & Dab plasterboard in the British & UK Tiling Forum area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Sealing Moisture resistant plasterboard Hi I am new here, I have been reading through many of...
10K
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Hi All. I'm installing a new shower enclosure and hoping for some advice on fixing the 12.5mm...
6K
hmtiling
H
Ok. Basically am i tilng right/prepping correctly? Full time professional tiler, nearly 15...
benchwarmer
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
