Guest viewing is limited
Discuss Dot n Dab around a door frame issues. in the Canada Tile Advice area at TilersForums.com.
Bubblecraft
Option 1 - Remove your facing, sheet on top of your standard leaving 3mm short. Tile up to your standard & bring your trim flush or refit your facing flush. You can fill to the thickness of your PB with Silicon.
Option 2 - Remove your facing, sheet on top of your standard running flush. Fill the ingles of your standard up to your door check with 4mm ply out to the depth of your tile. Tile up to your standard & bring your trim flush or refit your facing flush on top of your 4mm ply. You will need to plane the height of your door by 4mm & width by 8mm. This option is more work but a far better finish.
danmasey
Take architrave of, Do what you have to do re board tile etc. then a strip of wood around door frame to finished wall surface then architrave will fit back flush.
Strip of wood where mate? You mean something thin to cover the door frame itself? Like 5" wide? Meaning I'd have to plane te door down all round?? Or have am I getting confused?
charlie1
Think he means, remove facing , then tile up to standard. Rip piece of wood (thickness of tile+adhesive) and attatch to standard bringing standard level with face of tile then fit facing over top of tile :)
Reply to Dot n Dab around a door frame issues. in the Canada Tile Advice area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
When you guys overboard the subfloor with a backer board, do you undercut the door frame in...
What approach do you guys take when tiling a floor and you have the obstacle of a door frame...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
