bigbhudda69
Hello all and thanks again for the great welcome.
I have a job to do fixing various bits on a recently fitted porcelain tiled bathroom, I have never fixed through porcelain before and was after some advice, I have been pricing drills and hole cutters in all the usual diy sheds and the prices vary enormously as you are well aware of, I have been reading all the advice you give on drills and I am thinking of using 365.
The advice please, is it best to drill a slightly oversize hole through the tile and then use a standard masonary bit into the wall behind( i am thinking about the spread on the rawlplug maybe splitting the tile?) also could I use a say 8mm drill instead of using a 6mm and a 8mm as the fittings will cover the holes ?
Thanks for your help.
BB
BB
