Discuss drilling ceramics in the UK Tiling Forum area at TilersForums.com.
Deleted member 1779
Exactly right.
Ceramic is a very soft material. Break the glaze on the tile surface and the job is done. A bit of masking tape on the tile to stop it slipping.
You will need a basic tile drill which cost a few pound and are carbide steel.
Where our kit has a part to play is on more exotic stone like granite, porcelain, travertine, granite, slate, marble.
We produce commercial diamond drills to cut the very hardest materials out there. But of course the equipment upgrades come at a price.
Heres a couple of little projects on ceramics.
Project One
Project Two
These show other post readers what can be achieved with diamond drills in ceramics.
Our equipment is possibly too expensive for those who only have a few holes in ceramic tiles.
But for any other post readers who require the need to drill multiple holes into ceramic tiles with diamond crowns or holesaws then we can oblige. People like full time tilers, plumbers, builders and professionals.
macten
1,158
Nottingham
My tip for drilling grade 5 porcies is:
1. Mark the tile
2. Rotozip to make a depression
3. use a small (eg 2mm) tile bit as these gets through in no time
4. then use 6mm bit or whatever you need
Cuts drilling time down by loads.
Deleted member 1779
If you dont have access to the Rotozip (a basic 240v unit is £144.89 source TT)
Then for £29.99 we have 6mm drills which can be used with any hand drill.
£29.99 gets you a pack of FOUR core drills but also the anti-slip yellow guide plate critical for accurate drilling on those expensive porcelains !
Use the cores with a standard battery hand drill.
Also a wet sponge held under the diamond holesaw will cool it, maintain optimum lifespan of the core and eliminate dust exposure for the installer.
Perfect results !
mikethetile
I use a spear bit on ceramics and the advise given above is correct ie a square of tape to stop skidding
but take care with the plug, the head of the plug is wider than the hole so when srewing in you can crack the tile
so for a no5 plug[red] I use a 7mm bit and for a no 8 plug [brown] I use a 10mm bit and so on, this is just through the tile , once the tiles drilled I switch to the correct bit for the plug to drill the wall
Deleted member 1779
If you are a pro tiler then the BFKMX contains sizes for 6mm and 8mm so you can use them on ceramics. But the best thing is the kit contains the service pipe sizes.
Yes of course the kit drills perfect holes for rawl plugs.
You could use the spear points shown above left. But diamonds are more efficient
Here you can see the hole formed perfectly.
Just slip your plug in.
Job done !
The 6mm and 8mm form part of the kit.
And the plus is that they cut the holes for service pipes like the shower head above.
"All in one"
jwatson
for ceramic i always use a normal masonry bit for towel rails ect, and i have never cracked a single tile yet. my method is to mark the tile where hole is to be drilled. select hammer drill and simply mark the tile on hammer by drilling for a second. take hammer drill off and continue to drill hole. the bit will simply follow the mark you have made.
a steady hand is needed
diamondtiling
noy very good advice there j, hammer drill is not recommended at all.
:oops:
Reply to drilling ceramics in the UK Tiling Forum area at TilersForums.com
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits)...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
drilling ceramics
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
