Discuss Drilling/Cutting Porcelain - Bosch GTR 30CE in the Canada Tile Advice area at TilersForums.com.
Monkey Wrench
I'm considering buying a Bosch GTR 30CE Pro Tiler kit and, as this is a "dry" system, was wondering how long the cores actually last. I could buy some cheap bits, drill a few holes, and then replace them, but I also need a router bit for profiling tiles.
Is the Bosch GTR a good investment or could I do the same job far more cost effectively ?
Thanks in advance for any advice.
Monkey Wrench
Thank you for all the posts and the excellent advice.
Regarding profiling, I need a tool for cutting profiles around the bottom of door frames and other custom cuts that are not necessarily just round holes.
However, I get the point about the Bosch GTR and I'll spend my money more wisely elsewhere.
Thanks again.
Concrete guy
Ahh I see, that type of profile. I understand now.
I always used to saw the bottom of architraves off and slip the tile under rather than cut around it.
Reply to Drilling/Cutting Porcelain - Bosch GTR 30CE in the Canada Tile Advice area at TilersForums.com
Hello! We have an issue with 12 cracked large format thin porcelain tiles (1500x1500x6mm). They...
  • Sticky
Hi. I wonder if you can advise me. I need 4 inch hole drilled through the wall to install new...
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
5K
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
