reeves1985
Right I've dropped a bit of a boo boo and hoping someone may have a "cunning" solution .
I've mis measured the centre point along the bath wall (long side) which will be home to a double ended bath which has a fixing platform for the centre taps here's the bath just so you can picture what I mean
http://trojanplastics.co.uk/baths/double-ended-baths/miranda-1700x700/
This means taps will be dead centre
But on too of that the mis measurement has lead to me centralizing a concealed shower valve with fixed head and handheld from the wrong center
I'm reluctant to rip the wall off because it's now been tanked and I've skimmed the ceiling which all ties in
The bath needs to be chopped in to fit snugly by roughly 10mm and the centre point is off by 15mm
Titling wise from the centre point of the bath is going to be a vertical mosaic strip so as you can imagine it needs to line up so it doesn't look crap.
The. Bad centre has come about from having to square one wall up more than anticipated
Does anybody have any tips to "hide" this while tiling or is it a wall off jobbie
