Tiling Tool Suppliers
Discuss Dry cutter not cutting straight all way along in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
tails123
DIY Tiler
Altrincham
Hi there, been cutting 800 x 300 porcelain tile square cuts no problem for my bathroom walls however struggling to cut hex porcelain tiles corner to corner. The last 20 to 30mm breaks away from the score line. I checked the score and it does look or feel any different where the break veres off. Photo attached (ignore the jagged edge on rh tile I tried the nippers) Any advice welcome. Thanks.
Tony_C
528
Glasgow
Does your end that tails off always happen at the same end of the cutter? You may need to adjust your cutter for the correct height of the tile
Try double scoring the end that is not braking correctly. you could just be missing some pressure on the scoring action.
Try slowly breaking the tile with smaller push down actions with the breaker on the tile and slowly move up the tile doing the same instead of one swift snapping action.
wetcut/grind the top and tail then snap it providing you dont require both halves of the tile to be exactly half
Reply to Dry cutter not cutting straight all way along in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi everyone. Tiling my bathroom first time and going well so far! 600x300 ceramics on walls and...
Hi Gents, I've got two cutters, a TS-40 and a TS-60, along with a wet saw. However I'm finding...
6K
Seeking ideas for filling in a cut-out section of a porcelain tile floor. I removed a display...
Hello, I have a Sigma 66cms 2B3 tile cutter (I normally do small jobs, standard size tiles) but...
5K
L
Popular Tile Cutter Threads
tails123
DIY Tiler
Altrincham
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
