Discuss drying out fresh screed... in the British & UK Tiling Forum area at TilersForums.com.
Grace'sDad
My customer is having piped UFH installed in a couple of weeks into a new conservatory (20sqm). Assuming that it's going to be approx 60mm screed, am I right to say 1 day per mm for drying???
She is impatient and doesn't want to wait so what can be done to speed up the drying? Dehumidifier with heater???
Does anyone have reference to the "official" best practise where this is concerned?
The floor will be 600x400 travertine (with Ditra). Roof is already on.
Thanks in advance!
grumpygrouter
grumpygrouter
You are both missing the point here arnt you ?
As I said "as soon as your adhesive can be used "It has little to do with the mat you use its about the adhesive you use.
Both Ditra and Durabase are fixed with adhesive and can go down exactly the same time
tiler
Not really sure what you are trying to get at here Tiler, are you talking about the adhesive not sticking because of the moisture or shrinkage of the slab?
wetdec
I am saying the mat can be laid whenever you will be governed by what the adhesive manufacturer says about how soon the adhesive can be used on the green screed
You get me ??
tiler
grumpygrouter
I know what you are saying regarding manufacturers guidlines, I was just wondering if they say leave new screed for 6 weeks to give time for the slab to shrink or if it is because the moisture content would upset the adhesive curing.
I suspect that it has more to do with slab shrinkage than anything else and that is the reason Ditra, and I assume Durabase, say to use their mats, to isolate the tiling from the slab shrinkage. As most adhesives are water based anyway I don't think it has much to do with it effecting adhesion.
DHTiling
You can use any type of rapid-set or flexible depending on what the room is and type of concrete substrate.... i.e. wet heating / conservatory etc........the matting will bond no probs and any moisture will just evaporate in the Ditra channels......
A new screed will need about 5 days so you can walk on it and leave no footprints etc , then you can overlay with Ditra and tile.....
Reply to drying out fresh screed... in the British & UK Tiling Forum area at TilersForums.com
Hi all, this is my first post on here although in attempting to Google answers to my questions I...
5K
How long do you think it will take to dry out this screed? Been down 90 days, 50mm thick so...
6K
One Day
Hi All I have been to see a job last week,90m2 ground floor kitchen/conservatory. It will...
On one
Good morning all. Went to look at a job yesterday where they are having the nu heat Lo Pro 10...
rj1884
Hi all. Went to view a job last night, larger than I usually get these days. Rear of house just...
5K
gobby
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
