Discuss Drying time - Limestone tiles in the British & UK Tiling Forum area at TilersForums.com.
Terry Cottar
Can anyone give me some advice on how long it takes for limestone tiles to dry out after fitting? Because the walls were uneven a lot of adhesive was used (Keraflex Maxi) and the moisture is still coming through the limestone after 5 days. Can't seal until dry!
when you say moisture do you meandroplets of water or are there just damp patches?
tel
tileexperts
oops. i have seen this, limestone is very adsorbent, if there is a good lot of adhesive then it has come through the tiles and has stained it. i made this mistake myself about 3 years ago.
having said that, i could be wrong, but i am 99% sure thats wat has happened.
but wat i have done since is have my worker seal them before they went up. i know its crazy but am afraid of it happening again.
beanz
Berkshire
Would that not make it difficult for the addy to stick to the tile!?!
beanz
Berkshire
no. the stain has adsorbed into the tile. the addy will still stick, but it will show through the addy aswell,
but please dont hold me to this.
Maybe I should've been blonde, not bald, as i didn't get what you were saying here at all!?!?! :oops:
...the bonding coat had finish coat applied about a week before the tiles went up.. the patches are definitetly damp and drying from the centre out - but very slowly, they don't appear stained
How heavy/thick are these tiles? Most natural stone is too heavy for plaster, but having never even held Limestone i have no idea how heavy it is!?!?!
grumpygrouter
damp patches showing through matching exactly the 5 dabs of adhesive behind each tile (didn't trowel as walls were out..)
kereflex maxi can be trowelled to give a 15mm solid bed thickness when the tile is pressed into it. Dot and Dabbing is not a good method of fixing, neither, I suspect is the wall of sufficient strength to safely support the tiles and adhesive. Sounds like the tiles have "stained" and the marks are not going to go away.
Reply to Drying time - Limestone tiles in the British & UK Tiling Forum area at TilersForums.com
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
