Guest viewing is limited
Discuss Easy tile removal in the UK Tiling Forum area at TilersForums.com.
Colour Republic
Started a new job today - the tubbed adhesive must have been dry the second it hit the wall, there was a massive bow in the wall so they had put some one coat plaster over the top which was an inch thick in places, tiles flew off the wall - I'll post pictures tomorrow of the stud work they covered up:yikes:
sadly the same could'nt be said for the rendered wall, that really did take some abuse before we managed to clear it
[ame=http://www.youtube.com/watch?v=T4oA5MIfR4s]YouTube - tile removal[/ame]
suave
oh dear!
Colour Republic
Wait until about ten years time when everyone starts using bagged addy on cement boards. Wont be so easy then im afraid!
I for one am dreading it.
the reason it was so easy is because the one coat plaster was like filler, it must have drawn the moisture out instantly, the difference between that wall and the rendered was massive!
Anything left of the bath?
It's got a date with the skip in about an hour, then there won't be much left of the room let alone the bath:smilewinkgrin:
Colour Republic
I said I would post pictures of the wall in question... check this out!
Too long to go into to detail, but long and short of it is... 2 differnet firms fitting bathrooms (either side of this wall) had patched this up with rubbish results! I've never seen a wall do this so bad. I think this is just from the timber drying out and bowing not for any other reason. I estimate this wall to be about 20 years old (the house is 120)
about 800mm down from the split
i've sorted it now but camera died so I shall take pic tomorrow
Reply to Easy tile removal in the UK Tiling Forum area at TilersForums.com
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
Greetings All, appreciate the expertise existing in this forum. I am a home remodeler, not a...
5K
Hi everyone. First time poster and tile diy. Thanks in advance for any and all help, tidbits...
5K
Easy tile removal
