Discuss edging around bath in the UK Tiling Forum area at TilersForums.com.
macten
1,158
Nottingham
By all means use the plastic trims if you want a leaky bath and want to enjoy the yellow/black mould look in 10 months time!
Just leave a 2-3mm gap between tile and top of bath (fill bath with water so it flexes to it's lowest height) and run a bead of sanitary grade Silicon, preferably anti mould, to waterproof gap. Leave to set overnight and empty tub next day.
For internal corners leave 2-3mm movement joint and Silicon (not grout).
bugs183
Hear hear plastic bath trims are awful.
Check under the bath to see if the plumber has fitted a wooden batten for the bath roll to sit onto.
I bet he won't have, they never do.
Prop up the back edges bath with lengths of wood especially in the corners where they butt up against the wall.
This is the most common place that baths leak, and we tilers get blamed for the silicon cracking.
Nope it's the plumber, the baths moving!
Then do as macten says.
Reply to edging around bath in the UK Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi everyone. I'm really hoping you all can help as I am at my wits end. We have hired...
edging around bath
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
