Discuss effects of Silicon and grout on tanking membranes in the British & UK Tiling Forum area at TilersForums.com.
TMTservices
Just wondered if anyone knew the reason for keeping Silicon away from Impey membrane kits?
Only ask as I have found them in contact with each other when removing a wetroom floor which had failed.
Also in areas it looked as though grout had eaten away the membrane, why is this? Which type of grout causes this?
jay
TMTservices
I know that your not supposed to use it and that it clearly states not to, I was just wondering what the adverse efferct its suposed to have is? Its just when removing a wet room floor Ive noticed that who ever fit it has used Silicon in some areas, and I cant see any damage to membrane and its been down 2years +.
Cheers for pointing the epoxy bit out jay. I read that piece too and completely missed it. lol¬!
Another question I have, when buying the tanking kits you get a tube of jointing compound and block of putty. Does anyone know of anywhere to buy additional tubes or putty? Or any alternatives?
Thanks.
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
When I used to sell UFH, the blue thermal boards couldn't get touched by some adhesives and certainly not most primers. The reason for that was down to the fact that it sort of melted the surface and weakened compression strength.
Perhaps something similar with this?
Reply to effects of Silicon and grout on tanking membranes in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
Advice needed, noticed some grout that was cracked and tiles becoming loose in our en suite wet...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
