Guest viewing is limited
Discuss Efflorescence in the British & UK Tiling Forum area at TilersForums.com.
ajs201277
hi there i have had my bathroom walls and floors tiled in real slate and grouted with granfix maxigrout black grout but the joints have turned grey in various shades through effloresence i think but the tiles have been sealed could anybody tell me if i can darken the joints back down any suggestions would be very helpful
thanks adam
DHTiling
thanks dave for your input yes the grout has been sealed
Ok...you will need to remove the sealer...then leave it to dry...
2 grout colourants you can use...first is mapei fuga fresca...and the second being Aqua mix grout colourant which is epoxy based ..once applied and dried then you can re-seal the stone with the same sealer..
You MUST make sure everything is dry before each step....there are members on tilersforums who have used the colourants and will explain on the ease of use..
Just to add though and this will be the easiest method...strip the sealer and then leave to dry and seal with Aqua mix enrich and seal..this will darken the grout to a more uniform colour but will also darken the stone..what type of finish do you have now..matt or gloss.?
DHTiling
Ok.. i just looked online at that sealer...
They do a polish remover but not sure on how it works as i do not use that particular brand..you can then use the grout colourant and then re-seal with the same sealer as used before..making sure you follow all the directions very carefully...if you are unsure then please DO get this done by a pro..
We have a few members who do re-colorant work..:thumbsup:
Matt
I heard that tile giant stopped using granfix as there where too many come backs with there products. Doubt they will have this issue using a brand like Mapie though
Tile Giant have always sold Mapei. When we brought Tile It All and Tile Magic, they sold Granfix but we switched them to Mapei :thumbsup:
Reply to Efflorescence in the British & UK Tiling Forum area at TilersForums.com
Bathroom being refurbished. A load of things have been rushed like some loosely rollered (not...
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
Hi - any advice would be gratefully received. The colour of the grout in my bathroom varies...
Efflorescence
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
