Discuss Efflorescence in the UK Tiling Forum area at TilersForums.com.
What's the best product to get rid of some efflorescence. Grouted this bathroom yesterday with weber joint pro silver grey used it many times before with no issues.
Peter
What's the best way to prevent this from happening in the first place? Was using a lot of Profix Flexible grey grout specced for a builder that was drying out very patchy. Still have 3 or 4 bags in the garage that I won't use because it's a curse to get looking like anything. Tried with both a very wet sponge and a very dry sponge and both seemed to dry out the same.
DHTiling
By leaving the grout to set longer, firm to touch and then you will not soften the grout to causing polymer leaching..
Quite a few comps will sell products to help.. some grout haze removers work and others will not.. but over wetting and washing off to early is the cause 90% of the time.
Believe it or not Dave this grout was left at least 30 mins before cleaning and I can't see how I could of used any less water. Used it lots n never had issues so it must be something I've done different.
DHTiling
Was it firm to touch..? some slow setting groits take quite a while to set up and this can be increased with vitrified biscuits as they don't soak any moisture up..
I like to use ultra colour as it sets quick, just as i like it..
All i can say mate is use a white scotch pad and some élbow grease.. what tile type is it, natural or a looky like..?.. the other way is to re-colour the grout.
Reply to Efflorescence in the UK Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Warrington Cheshire
Efflorescence
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
