Hadb11
I am considering purchasing the Wedi system for a shower renovation.
The current shower setup uses an electric shower and the new shower renovation will also use an electric shower.
The current electric cable runs from the studs, through the tile backer board, through the tile and then into the electric shower unit.
When the tile backer board is replaced with Wedi board, can the electric cable be run through the Wedi board? Does it need a certain clearance around the cable or is there additional protection that can put around the cable such as a sealing gaiter?
I want to ensure that running the electric cable through the foam backer board does not create a fire risk and that any necessary precautions are taken.
Also is there any documentation or training videos that use an electric shower when installing a Wedi system?
Many thanks in advance for any advice.
