Discuss Electric heaters contactor wiring question Electrical Advice in the Electrical Advice area at TilersForums.com.
Electric heaters contactor wiring question Discussion ThreadElectric heaters contactor wiring question Electrical Advice
Hi ,
I have been tasked with putting 4 , 2kw panel heaters in a portacabin .
I plan on wiring four 16a radials to each circuit ( fused spur at each heater). These will be controlled by a 24/7 time clock. Back at the CU.
My question is to do with the contactors .
I was planning on feeding the time clock with a control circuit which will switch the contactor coil .
Am I able to use a 4 pole contactor to switch the lives only , or do I need an individual contactor for each circuit.
And also if I can use a 4 pole , is it normally rated per pole , or do I need to get say a 40a .
Thanks in advance
Electric heaters contactor wiring question for the original thread on Electricians Forums
Reply to Electric heaters contactor wiring question Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
