Guest viewing is limited
Discuss Electric Tile Saw/ Cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
ACB.tiling
Quality tool for accurate cutting of all types of tiles
• Mitre, bevel and compound cuts
• Laser line generator for spot- on alignment
• 800W quiet induction motor
• Water pump cools & eliminates dust
• Generous aluminium cutting table 785 x 385mm
• Cutting depth at 90°: 30mm
• Waterproof No-Volt safety switch
• Motor glides on four sealed ball bearings
Model: TC200III
Blade Speed: 3.000rpm
Max Capacity: 560mm
Max Depth of Cut @ 45deg: 25mm
Max Depth of Cut @ 90deg: 30mm
Nett Weight: 31kg
Overall L x W x H: 950 x 580 x 930mm
Power: 800W
Rating: Trade
Table Height on Stand: 700mm
Table Size: 785 x 385mm
Tilt: 0-45°
Blade Dia/Bore: 200mm/25.4mm
Only used a couple of times. £100
Reply to Electric Tile Saw/ Cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hi Gents, I've got two cutters, a TS-40 and a TS-60, along with a wet saw. However I'm finding...
6K
Hi, new to forum but tiled a few DIY jobs for friends and family over the years. Can anyone...
10K
Hello all What are the benefits of a bridge saw over a “normal” push though electric cutter. ...
5K
Looking for recommendations for the Job I’m doing in a fortnight as theyve just told me the...
5K
Hi Guys, First time tiler here part way through tiling my bathroom. I purchased a Sigma Series 3...
15K
Popular Tile Cutter Threads
