Discuss Encaustic tile troubles in the UK Tiling Forum area at TilersForums.com.
Rina2
I am not a tiler, just a woman with tiles. I had new cement encaustic tiles laid down about two weeks ago. First a sealer was applied then a grout. I bought the brand recommended by the manufacturer. The grout seems to have left a greasy film which I am having a very hard time removing. It makes my floor look grimy. Most of the floor is solid with a border design, making the mess more visible. The second problem is that when I move the table or frig it leaves a scratch on the surface. I wouldn't say a deep scratch, but not something I look forward to accumulating over time.
I would appreciate any professional input. I am at my wits end. Thanks very much, Rina
simplythebest
228
I can almost guarantee that it wont be the sealer but more likely the grout staining, i always use 2 pre-coats of sealer prior to grouting and even then the grout always leaves residue, this is removed with a cleaner then i follow with another seal and after that waxxing to give maximum protection.
Encaustic have a very particular method of installation and must be kept meticulously clean throughout the whole laying process.
If you are not practiced laying them you WILL have problems.
hope you get them sorted.
m3fitter
these tiles require sealant and cobblewax to finish and protect, the Encaustic cement tile is unstable until waxed, i would recommend lithofin waxoff, then a deep clean with alkaline based lithofin easy mncare, then reseal with MN Stainstop and finally Lithofin cobblewax, left on for 10-15 mins and buffed. Initially strip the tiles and clean to desired finish, prior to protecting Rita.
Reply to Encaustic tile troubles in the UK Tiling Forum area at TilersForums.com
Hello, I am hoping I may be able to get some advice. 2 years ago we had a new kitchen fitted and...
I had my bathroom done in September and my floor tiles have movement in them and the grout is...
Hi, I have had both polished and matt textured wood effect tiles laid in my house and am having...
7K
Hi all Having a bit of a mare; after having my last shower installation botched (but thankfully...
7K
Perfect Tiling
Dear TilersForum Thank you so much for the outstanding advice and expert information over time...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
