Discuss Epoxy grout in the Canada Tile Advice area at TilersForums.com.
Hello folks can anyone recommend a good easy to use epoxy grout I've used it before a few years ago so I'm not used to using it and any technique or the best way to apply it would be great also what other tools would I need ive still got my epoxy squeegee from years back but that's about it.
thanks for your help
peter
Turkish tiler
I have received kerapoxy from mapei, easy to use I have ordered mapei epoxy floater is well nice tool.
get few hard sponges (epoxy grout sponge).
they do all colours as they do in ultra plus grout accept black
start with 2m2 first apply to finish then you know your speed
if you are not sure with anything just call mapei tech help :smilewinkgrin:
MTiler
Get plenty of white emulsyfing pads, I use sponge cloths instead of sponges because they just get clogged up. Always wear Nitrile gloves. Use plenty of water, warm if possible.
I use Kerapoxy alot and its a pig to use. As soon as youve applied the full pot clean it off straight away. If a 5kg pot is too much just do a half at a time (using scales). Acetone can be used to remove any stickyness and clean tools.
missyT
Reply to Epoxy grout in the Canada Tile Advice area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
Have seen a social media 'look how great this stuff is' recommending the use of this stuff: Is...
Hi any info on get rid of epoxy grout haze on natural stone would be much appreciated. I’ve used...
liverpool
Epoxy grout
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
