Guest viewing is limited
Discuss Ever tiled a garden ?? in the UK Tiling Forum area at TilersForums.com.
david campbell
600mm :yikes::yikes::yikes:
Thats a huge hole you could park a small country on a base that thick!
Personally id go for a hardcore base 150mm of MOT of type 1 whacked with a whacker plate. Then lay your contrete/scred base onto that. Thats how i have always prepped a base for slabs. 200mm subbase if its for vehicles
thats the minimum for a raft foundation,supposedly the weight holds it in place,for strip foundations you can go 450mm due to the size and nature, they are supposedly less prone to movement.....not my rules
Reply to Ever tiled a garden ?? in the UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
