Discuss Everbuild SBR Bond as primer in the UK Tiling Forum area at TilersForums.com.
janzbro
Hi, is this suitable to prime a bathroom plasterboard walls prior to tiling with 31 x 45 ceramic tiles.
I believe Dave first posted about this stuff
Also do I paint / roller this on over a tanked shower area?
Cheers :8:
DHTiling
You prime before you tank not afterwards....:thumbsup: ...
SBR primer from everbuild is fine for priming....
And is available from tradetiler at a good price..
SBR Bonding/Admix agent - (Everbuild)
(Do not be tempted to use cheaper PVA which moisture breaks down)
SBR Bond is a latex based - Highly suited for priming areas before tiling
Water resistant bonding/priming agent and admixture for use in areas subject to humidity, dampness and continuous water contact
Improves water resistance of cement mixtures by forming a reinforcing polymer that increases long term durability and flexibility of the mix on renderings and floor screeds adhesive etc.
Can be diluted up to 3:1 with water - follow instuction on bottle
Price: £11.99 £13.79 Including VAT at 15%
Tradetiler Tilers Silicon and tools
janzbro
Found it at Joeseph Parr (Middlesbrough) for £10.95 or£12.59 Including VAT at 15% if anybody from the Teesside area is looking
Do I just paint / roller this on neat or does it need to be watered down
Would it be suitable for using as a primer before using Mapei Adesilex P9 Flexi Adhesive or would Mapei Primer G be better (same range) in a shower room onto plaster board fitting Ceramic tiles
Reply to Everbuild SBR Bond as primer in the UK Tiling Forum area at TilersForums.com
Hiya, just had a long discussion at Topps Tiles about which primer would be best to use under...
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
