Discuss expansion joints in granite floor tiles for area 300sqm in the Best Floor Tiles area at TilersForums.com.
archer
Hi there,
i have recently been asked to tile an area of about 320sqm with granite floor tiles. the screed has not been layed yet and i was wondering at what intervals the expansion joints should be laid, wether they must match the saw or cold joints in the screed, i phoned the suppliers of the tiles and he suggested using a polymer grout as expansion. also would a normal cement based adhesive do the trick or would a flexible one be a safe option?
cheers
matt
diamondtiling
Expansion gaps vary depending on the architects mood :20: Some say 5 metres and others say 8. Is there an architect on the job that you could speak with?
Is this a ground floor that you are tiling?
A SPF would be advisable over normal rapid set.
What is the project? Is it going to have much traffic? if so how heavy?
:thumbsup::thumbsup:
archer
thanks, think i already knew that, been a slow day today. no i havent tackled anything this size before, i havent commited myself to anything yet, im just trying to learn about every single aspect of it and the solutions. i looked at the schulter website. was wondering if there was a knack to laying them having not done expansion joints before but i suppose everyone has to start somewhere? as long as its done correctly.
Terry Cottar
Thats a fairly big job for any tiler! What size are the tiles and how do they want them laid?
tel
I would use the preformed schluter ones for a jobn that size m8.
Over 40 m2 area your should have expansion gaps every 5m if it's heavily used traffic area, schluter does brilliant expansion trim especially for that, if its 1 big area just divide area 320 m2 in 25m2 it will be 12 square sections, between sections should be shluter expansion trim
good luck
Reply to expansion joints in granite floor tiles for area 300sqm in the Best Floor Tiles area at TilersForums.com
Hi, Looking for some advice regarding tiling over expansion joints in floor screed. I’m getting...
gamer1
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
Best Floor Tiles
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
