Discuss Extenal tiling should I protect tiles from rain until grouting? in the UK Tiling Forum area at TilersForums.com.
H
heavytrevy
Cement glues dry via chemical reaction not evaporation ? unless your thinking bout Mastic type glues.
Trapped water under tiles will always result in efflorescence and patchy grout , doesn't look pretty
Trev
I see what your saying but the adhesive has a high water content in it when the tiles are initially laid...grouting same day would trap this underneath the tiles.
I'm heading over now to cover as you lot have made me really paranoid!
:yikes:
Richard Edwards
Spot on replies to this issue
Bal fast flex is a polymer enhanced cement based ady with fine rubber crumb and is a brillant ady to use on that application. I wont ask you what prep you have done prior to tiling as the tiles are now down and you only get the colly wobbles and go into a decline even further.
Now about this water under the tile.
If it has got wet already, ie rain on it - cover it and wait for a really warm spell so the tiles heat up and wait a couple of days to dry out all the voids between the ady bedding, then grout it and be sure to add a polymer to the grout or grout with a top qual flexible external rated grout . If you managed to keep it dry - grout asap in the dry.
F
FreeD
Ok to follow on from this the customer has now requested that the top of the tiles are cleaned. The tiles have been relayed and some have algae etc on them. I was planning on using Aqua Mix heavy duty tile and grout cleaner. Guess i'm going to have to do this before grouting (they are using a light colour grout)? and be careful not to get the cleaner/water between the joints? then grout...what do you recommend?
Richard Edwards
Hi FreeD
I am a bit confused here - If the tiles have / had Algae on them, then presummably there must have been an extended time gap between inital fixing with Bal Fast flex and the present time. When u say that the tiles have been relayed, are you saying that u have lifted them recently and relayed them ?
I would consider using a deep cleaner or biocyide to kill the algae and you will have to accept that washing water and rinse water will get in to the grout joints. Then wait for a dry spell with sunshine on the tile surface to dry out the undertile before grouting.
If the balcony is free-draining I might consider a pressure washer then allow it to dry out fully before grouting -- Sounds a bit of problem there me old lover [Thats Bristolian speak for my mate ]
If you are using light coloured grout externally - you might consider grout protection spray or solution from LTP range
Reply to Extenal tiling should I protect tiles from rain until grouting? in the UK Tiling Forum area at TilersForums.com
