robthebubble
Hi all,
I need some advice please and hopefully one of you fine people out there can point me in the right direction!
I'm currently building an external pizza oven which is on a standard dense block work wall with concrete top (walls are only 1.2m x 1m high). I've got a number of granite slabs which are smooth on the back and honed on the front (slabs are 80 x 20 x 2cm).
What I want to do is use these slabs to clad the wall however I'm not sure of the process. I have the usual SBR slurry I can use on the back of the slabs but should I prep the wall first or is it a straight forward wall adhesive and grout? As you can see it's only a small area of wall which needs doing.
Any help would be appreciated.
Rob
Rob
