Discuss External self levelling ideas? in the Canada Tile Advice area at TilersForums.com.
Chewie
Swindon
There are very few levellers suitable for outdoor use mainly due to the fact they are moisture and frost tolerant . A suitable one is ardex k301 and check this F. Ball stopgap 850 .
Thank you sir, Ill check it out. I’ve just seen a Wickes product with is for external applications....
Dumbo
Tilemaster Flexilevel can be used outside under certain conditions - I think that if it is not the finished surface and won't be subject to long periods of sitting water - but double check with their tech dept.
I spoke to tilemaster recently and they said they don't have an external grade leveller
I
Italy
I think your English is in question.
The OP states has anyone used Wickes products for external levelling?
Therefore, you either have or you haven’t.
Zzzzz
since there are answers that speak of self-leveling and leveling,
provided you know the difference.
if only you knew what Wickes products are used for
here in Italy.....
buongiorno
Tile Shop
Zzzzz
That's a bit mean... he's Italian and has to use google translate, which is only 50% accurate at the best of times.... Cazzo is his favourite word, he did very well to refrain from using it.
I haven't. So if that's all you want to hear, I'll keep all the better suggestions to myself :)
For the record, all the Setcrete compounds on Wickes website are for internal use only. Unless they have a one-off at your local store you are intent on using.
Good luck.
Reply to External self levelling ideas? in the Canada Tile Advice area at TilersForums.com
Hello, question for tilers using xl bond self smoothing compound. Normally use sika or mapei...
osie12
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Hi guys, had some great advice here before so thought I would ask here for advice again...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Swindon
Business Name
Lustre
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
