Discuss F.Tiler in the UK Tiling Forum area at TilersForums.com.
19x35 tile batten screwed to the wall. Cellotex cut in between use 35mm Cellotex then screw 6mm Hardibacker board to the battens to give you a surface suitable to tile onto. (i assume 6mm is suitable for walls but the pro tilers will be able to say for sure)
Reply to F.Tiler in the UK Tiling Forum area at TilersForums.com
