Been to do some 'cosmetic' work on a floor today.
When I got there, cracks all over grout but no broken tiles. Most sounded hollow when tapped and suspected dot n dab. Question is, the method used for failed uncoupling mats (resin injection) would be an option. Not seen this before so not sure of the process. When I took the cracked grout out I could see a void of about 10mm to floor, confirming my suspicions. Would the resin injection method work on a void that size or only on a fraction of that. I'm asking this as the whole floor would have to come up otherwise. The kitchen units and large island are also fitted on top so it will be expensive to remove as its about 65m2.
Any input would help cheers
