bugs183
So at last one of my worst nightmares has come true, i have a faulty u'f'h mat.
The floor is concrete, then marmox 6mm boarding. Two electric under floor heating mats, both resistance and continuity tested by myself and the electician whilst rolled up. Now i always put testers on, and i use a tester on each mat as i lay the mat and level. The electrician, connected both mats together and told me it would work ok off one sensor. I couldn't see how but he told me it was fine. Floor was levelled, everything seemed ok, tiled the floor, everything seemed ok.
Now i can't remember doing a final continuity test before i left the job on each mat. Being a bit of a worrier and a realist, not an optimist, i'm 95% certain i would have tested both mats independantly, but i'm only human, so i can't say for certain.
The electrician wired it up at a later date, felt the floor warm up, and thought everything was fine, but it wasn't he didn't check to see if the other area was warming up
Now i'm not here to blame anyone, i just need some help, and to also lead by my own mistakes. If you have two mats always use two testers, test at every stage possible, and if at all possible have the electrician double check too. Sounds like common sense, but i've done lots of these and it's easy to be complacent.
I've heard that through thermal imaging the area where the fault is can be found, does anyone know of a specialist that can do this in the Gloucs area?
Any help would be greatly appreciated.
JB.
JB.
