Feeding a mains outlet from a PDU. Discussion ThreadFeeding a mains outlet from a PDU. Electrical Advice
Good afternoon All,
i have been advised that it's ok to install a double gang standard mains socket on a piece of furniture fed from a 10amp outlet of a 6 way 3 pin plug power distribution block. Can this be done by using a 10amp fuse in the plug that feeds the outlet?
I don't believe this is right, but would like to know the reasons why so i can put them to the 'powers that be', at which point get an electrician in if necessary... Thank you all!
Feeding a mains outlet from a PDU. for the original thread on Electricians Forums
Good afternoon All,
