Discuss Ferrule for triple solid core CPC in socket w/metal back box Electrical Advice in the Electrical Advice area at TilersForums.com.
Ferrule for triple solid core CPC in socket w/metal back box Discussion ThreadFerrule for triple solid core CPC in socket w/metal back box Electrical Advice
Ancillary to my other post, I wanted to check if something was up to standard in part of the installation I'm doing.
We have a metal back box in this case. I've got a fly lead going to the face plate, which has the two other CPC cables going to it also. I've not been happy with how sturdy the connection is if I use 3 solid core conductors into the single terminal especially with the loose 4mm sheathing for the earths. One always seems to want to pop out. MK Logic back boxes.
I decided to use a ferrule to connect the triple CPC together and then insert in the faceplate terminal. I'm just not sure about crimped ferrules on solid core cable. It seems to be rock solid, but wanted to check I've not erred.
Am I good or should I try for an alternative solution such as a wago?
The ferrule used is a fluted knipex E-Cu ferrule of the non insulated type like below:
[ElectriciansForums.net] Ferrule for triple solid core CPC in socket w/metal back box
The tool used was a pair of knipex self adjusting crimping pliers:
Ferrule for triple solid core CPC in socket w/metal back box for the original thread on Electricians Forums
Reply to Ferrule for triple solid core CPC in socket w/metal back box Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
