filling 10mm gap
petey
Hi folks.
Fitting a 1600 shower-bath in a 1625 gap, and taking into account the tiles and adhesive, the bath will leave an 18mm gap (give or take).
I cant really dot/dab plasterboard to either sidewall to make the gap up, as one has a door, and the other has a window.
The rest of the bathroom is not being tiled, but I figured I could tile a small area around the 'head-rest' end of the bath (imagine like a splashback on sink) and think that would look okay, but the tiles will only account for 10mm, not the 20mm I need.
Could I cut a piece of hardibacker the same size as splashback area, and tile onto that? Trouble is - how do I fix the hardibacker to the wall, and how do I deal with the 10mm return-edge on it ?
Any advice ?
Thanks.
once tiled it would leave a 5mm gap at each end so this could just be siliconed.
or use 9.5mm plaster board or hardibacker above one end of the bath, then use a thicker trim it cover both the tile and backerboard
or use 6mm hardibacker on both ends of the bath and again use thicker trim to cover at both ends
filling 10mm gap
petey,
Colour Republic,
petey,
Colour Republic,
