Discuss Filling gaps in sub floor in the Canada Tile Advice area at TilersForums.com.
V
vrytir
Hi, i have wooden floor on which i want use tilemate boards and ufh on these then self leveling compound then tile on this. Question is should I fill gaps between wooden boards with something or just spread the adhesive and dont bother about gaps? Should I also use primer g before spreading adhesive?
I know I use adhesive to fill gaps between tilemate boards.
Ajax123
1,213
Lincolnshire
3mm gaps won't need per filing and to be honest filling them might be counterproductive as it would restrain expansion and contraction. I would make sure they are securely screwed and would deffo consider screwing the insulation boards down using screws with washers....
Reply to Filling gaps in sub floor in the Canada Tile Advice area at TilersForums.com
Im changing a bath to a tray for a friend and the bath was chased into the wall on all 3 sides...
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Hello everyone. My building had bricking work done on the outside and it seems in the process...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
