Discuss Filling the gap between wall and tiles. What product? in the UK Tiling Forum area at TilersForums.com.
Collision
Hi. I wonder if anyone can help. I've recently finished tiling our floor with large porcelain tiles, 100 m2 total surface area. It's an old stone farmhouse and the bare stone walls are obviously very uneven (If you put a straight edge along the wall there would be gaps up to 8 cm).
I've cut the tiles to (roughly) follow the unevenness of the stone walls and left a gap for expansion. The gap varies from 4mm to 30mm and I'm looking for a material to fill the gap.
Normally the gap would be covered over by skirtings but there aren't any (nor practical because of uneven walls)
Another option might be Silicon or mastic but I don't think that's going to be a satisfactory finish. The gap is too wide in places to get the Silicon flat, I'd use dozens of tubes of the stuff, Silicon wouldn't be a matt enough finish and I'd probably end up with it half way up the walls too.
What I'm really looking for is something like a flexible grout, so that it's easy to work with, fill large gaps, apply easily to give a flat finish and also a matt finish. But not just flexible grout because that's going to crack with any movement.
Does anyone know of any product on the market that fits the bill? Or come up against a similar problem themselves?
Many thanks for any replies.
Hi and welcome to tilersforums.com
Not to be picky but couldn't you have scribed the tiles to give a better finish, then Silicon the 2 / 3mm, a 30mm gap is going to stand out against the smaller ones, no matter what you use, how many of the larger gap spaces are there ? could you replace the ones that need to be ?
Collision
Hi Alan. You're not being picky! It's a bare stone wall with so many curves, bumps and irregularities that scribing each contour wasn't really practical. Tiles are 65 x 45, most have 6-8 different cuts (on the wall side) and as there are 11 different rooms within the 100 m2 that's an awful lot of tiles I'd have to lift back up.
John Benton
1,138
Leeds
If you going to fill that gap sand/cement would be my choice, others may have a better solution.
My choice too, it must match the mortar colour on the wall, to be a continuation from the wall. It would blend in better and not be as noticeable.
Collision
Sorry guys, I'm confused. If I fill the gap with grout or sand and cement am I not risking cracking from movement due to expansion and contraction? I left the gap deliberately to allow for expansion, if I didn't would I not have run the risk of tiles cracking?
Ps. For clarity; the gap between wall and tile is between 4 and 30 mm. The reason for such a variance itn he width of the expansion gap is the roughness of the bare stone walls. Imagine a very rough drystone dyke and you're still not close!
bugs183
Try and source the local sand that was used to build the walls, mix that at 3 parts sand to one part cement ,and mix with SBR.
Rough point between the wall and the tiles. Leave until its just starting to set and then mould to the desired shape with a small trowel and an old brush.
The SBR should give the cement enough flex, silicon is going to look awful.
Reply to Filling the gap between wall and tiles. What product? in the UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hello, I have some lovely Mexican terracotta tiles (glazed on one side only) which are meant...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
    Votes: 5 4.5%
    Votes: 8 7.2%
    Votes: 7 6.3%
    Votes: 32 28.8%
    Votes: 14 12.6%
    Votes: 28 25.2%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.1%
    Votes: 18 16.2%
    Votes: 13 11.7%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
