Discuss Finding the highest point of a floor in the British & UK Tiling Forum area at TilersForums.com.
Swanseajack
Another way to check levels around a room, is to run a datum line around the room, say 6 inches up from the floor using a long level. Then measure down from datum line to check high/low spots.
I have a 1.9mtr Stanley Fatmax Level, and use Oli's method to measure acroos the centre of the room.
Another option is to use a water level, these are great for measuring through multi rooms.
Andy Tiler
1,043
manchester
Say u've got a 30m2 floor and you want to start tiling from the highest point...how do u find the highest point?
thanks
hi freed i have 2.5 and 3m aluminium strait edges i pass them over the floor with a spirit level on top. but if ur floors that far out u should b useing slc :thumbsup:
F
Frosty
For a straight edge I use a 3m length of aluminium "I" beam used in demountable office partitions.
It's very cheap to buy one (or "borrow" it from a site) and they're very sturdy. Can easily be cut down to required length aswell.
Just put a level on top of it, spacers underneath ( 4" square ply offcuts) and sling it across the room to measure dips/high points.
Reply to Finding the highest point of a floor in the British & UK Tiling Forum area at TilersForums.com
Hey guys, I'm going to tile the patio and need my new porcelain tiles (10mm) to meet up with...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
How would you go about tiling a floor and or wall that's massively out of plumb ? When things...
    Votes: 9 5.9%
    Votes: 14 9.2%
    Votes: 11 7.2%
    Votes: 44 28.9%
    Votes: 19 12.5%
    Votes: 36 23.7%
    Votes: 21 13.8%
    Votes: 18 11.8%
    Votes: 16 10.5%
    Votes: 7 4.6%
    Votes: 4 2.6%
