Discuss Finishing a shower off, nervous about existing work in the UK Tiling Forum area at TilersForums.com.
Tynan
Hello all, I'm trying to finish various uncomplete jobs around the house after a builder walked away, his work was generally sound i think but towards the end he started hurrying stuff and cutting corners
At this momemt I'm tryng to complete a downstairs shower room. The shower body is in place and I've plumbed water into it and am ready to tile the back wall and tile it, at this point after some googling as to what to watch out for I have some doubts.
the left wall is tiled straight on to plaster, it's the party wall so maybe skimmed onto that? I can certainly see plaster under the tiles.
The right wall seems to be tiled straight onto some sort of ply, it's quite a mid brown and smooth so I'm hoping marine ply but no real idea, that's a stud wall built to form the shower room
The back wall ... there's 2x3 framework and four panels of ply that have a hole cut for the shower body, there's a recess of about a foot behind this and then a brick wall with the 'under the stairs' behind it, the supply comes from there and then through the wall.
I suspect the ply here is bog standard ply from the feel of it, there's also some voids in the central layer between the segments of that layer
I'm a humble DIYer and not that handy,I was happy plumbing and tiling this in, I'm now worried about a few things before I proceed ...
A. Is the tiling onto plaster on the brick wall going to be ok as regards waterproof and tiles staying up
B. Is the tiling on the ply wall going to be ok regard water and tiles
C. What to do with the back wall, is treating it with something and making sure it's well secured going to be good enough?
D. And finally, the metal shower frame for the door appears to be screwed directly to the tiles, it doesn;t look to be waterproof in any way to even an optimist, should it not have some sort of seal?
I've taken a heavy breather video that tries to show the ply wall, the edge of two sheets of the back wall ply, the plaster on the party plastered wall and finally the metal door frame screwed to the tiles
[video]http://www.ruedelagare.co.uk/CAM/VID00015.MP4[/video] (takes a while to load)
Is it sensible to carry on and finish the job as it stands or does it need all taking down and starting again, I've seen the tanking installation vids and they look very sensible.
The shower space is ground floor if that matters
many thanks, I really wanted to get this done this week but I don't want to be doing it again in the forseeable future
Tynan
Tynan
Hi
I was hoping the vid would do that? Can you see it?
Two walls are already tiled, they're 'Barbetti Gres Porcellato - Full Body Stoneware' measuring 12"x21"
Here's some photos
The shower frame screwed to the tiles, metal frame stright to tile as far as i can see
View of the ply used for the back wall, showing a void? means it's not Marine ply?
The ply? behind the tiling on the stud wall, where it meets the back wall
The edge of the lower two pieces of ply on the back wall
The plaster behind the tiles on the party brick wall
Tynan
I can see what I assume is behind the two walls of tiles up, in the gap between the tiles and and the back wall, ie the space for the back wall's ply and the back wall's tile, it's what I've tried to show in the pictures
I did have some professionals out a year ago who certainly mentioned that they'd have used cement board and mounted the door frame differently, although they also said the job so far was ok and they had no problem finishing it, but perhaps they're were happy just to finish off rather than tell me about problems
I have no idea what he used, sorry, he worked while we were both out out work, I trusted him to get on with (yes I know)
Tynan
I now recall, in the bulider's defence that it's a tight fit for the tray, it's an exact fit between the party and stud walls, there wasn't much to spare between the width of the shower tray and the corridor outside
but that said, I presume the cement board or whatever isn't go take much space up and if necessary could slightly ovelap over the tray?
Tynan
thank-you
the wife has given the ok to rip it all down and start from scratch with cement board and tanking if there's doubt about the way it's been dome until now
but the time and cost is a bloody pain, remebering how to plumb and tile is enough ag for me, she reminded me about next door's tales of wofe about having their new shower tiled three times before it was right and stopped leaking
Tynan
Hello again, I'm not surw what I've done to get such a limited response
Anyway, after much sucking of teetch and readin up I'm about to do the back wall with Aqua panel and have just finished the stud wall and plumbed in the shower body, I'm ready to start puttig up the Aquapanel, the bit I'm struggling to visualise is the join between the pipework and the shower as it passes through the tiles, I have all the right connectors but I ca;t quite see the best way to get the connection from behind the tiles just right for the shower bit to slide onto the end of the brass fitting, it seems like it'll have be just right, am I supposed to do it with dead reckoning?
Aslo, how should I seal the hole through the Aquapanel and the tile? I have a diamond hold drill to make a nice neat hole (hopefully) but what's the procedure for sealing between the hold and the pipework? Silicon or adhesive or is there some sort of rubber seal that I'm yet to see?
Sorry about the flapping, first time job for me and I', a natural worrier
diamondtiling
Seal the holes with clear Silicon before tiling, also seal the gaps between the panels if you have not taped them. Getting the position of the connections is crucial, too much clearance and your control bar will be proud, too little and you will struggle to fix the bar. These items have a tolerance either way, usually about 5-10mm. Check the instructions.
Sometimes posts can get lost on the forum, that is not down to indifference on our side, just a heck of a lot of people posting many questions.
It might be best if you steered your thread with regular input on your progress.
Any more questions just ask away
:thumbsup:
Tynan
Thank-you
Cool, so dead reckoning and then fill the space around the joins with Silicon, is it sensible to leave the pipework behind the board and tiles with some play to allow for wiggle or should it be clipped solid?
I suppose with a piece of board and a piece of tile I can mock it up
Do you mean the tolerance where the shower connector slides onto the brass fitting coming through the tile?
The shower instructions don't extend beyond the surface of the tiles
Tynan
oh, and I have the aquapanel tape for the joints
I've squinted at the join between the connector and the inital piece of the showerr and there does seem to be a little bit of tolerance
the join is what I think is called a right angle elbow, it's round with a screw fitting on the side for the shower hose and a opening along the axis for the end of the brass connector to slide into, the two rubber O rings make a tight fit, I assume that that tight fit is all it uses to hold it together? The chap in the plumbers merchant said so, the shower is a Moonshadow SC
Reply to Finishing a shower off, nervous about existing work in the UK Tiling Forum area at TilersForums.com
Hi, I’ve just crossed over from the plumbers forum for some tiling advice as I’m in the process...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
