Discuss Finishing grout lines in the UK Tiling Forum area at TilersForums.com.
widler
1,328
England
got to use a rounded end implement imo nine is a piece of wood whittled down and rounded ,but you can buy them from all good tile shops just cant think what they are called at the mo
tile grout line thingies will do ;)
i just use a sponge as well
siremastimus
OK thanks so does this look correct:
Apply grout and work into gaps using float corners
Remove excess grout with float (long edge primarily)
Allow to dry for about 10 - 20 mins or so and then wipe of diagonally with sponge and lightly down joints with sponge
Once fully dried wipe over again to remove haze etc
Peter
Depends on the grout type, make, tile, room temperature etc for when to wipe off. Best time is when the joint has started to stiffen up and is not watery or going into pinholes - usually when it starts to cake on the tile. Better testing every few minutes if you're not sure. Check if the tile needs sealing before grouting too.
Then a second wash with clean water a few hours later and finally buff up with a terry cloth next day.
bugs183
As above.
We either strike our joints with a bluntened stick, but some tiles suit going over just with a sponge.
The grout type makes a difference, especially modified types. These need a damp wipe over an area 1-2m2 just to break the polymers down so they don't stick to the tile face, then you can go over with more detail.
Best do about 1m2 then see how the grout is drying, everyday is different!
Then as above, wash again, then buff up.
Reply to Finishing grout lines in the UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
