TIM
Hi peeps, this is my first diy tile job in a small box room of the kitchen.
I have started on the main wall as you go into the room, I used a straight starting baton and have tiled outwards and have now got to first internal corner.
So I cut the edge tiles leaving a gap for the Silicon as you should.
So using another baton which has been set level from the tile line of the completed wall I was going to continue but I have a problem.
The damm wall internal corner is terrible, I cannot get a straight fininsh in the corner if i go from the straight edge of the baton,I will have a horrid gap.
The gap would be small at the bottom but as much as 15 mm to the top of the corner.
I do not know what to do for the best now, should I just cut the corner tiles as best as I can and hide them with trim?
Or can you tell me a better way- do not want to skim wall the room is tiny 6 foot x 3*11.
Thank you
Tim.
Thank you
Tim.
