monkeycat
Hi all,
Got my first job starting on wednesday.
Went to see it on Saturday, it about 5sqm kitchen splashback with thge bottom part of the window to cut round.
The wall with the window has had a bond coat of plaster on it. Will I be able to skim this with rapidset when I get there and then prime it and tile onto it after 3 hours?
One wall has wallpaper on it and 2 walls have tiles on. The customer has agreed to remove all of these and get the walls as flat as possible before I start.
He hasn't got the tiles yet, but he wants small, cheap tiles so I'm expecting b and q.
I'm planning on using blue or green star adhesive and the buildfix(mapei) rapidset from b and q to do the skim, will these be ok?
Also the worktop is at two different heights so should I start with a full tile from the lower height and cut the rest?
He has also started doing the bathroom himself, but has not made a very good job of it. 300 x 300 tiles (the ones that look like mosaics but are on a big tile). He hasn't used spacers and the tiles are butted up against each other. He asked if I could finish that for him but I advised him it would be best to start again because the tiles need grout in between.
What advice can I give him for removing the tiles and getting the adhesive off the back?
Paul
Paul
