Discuss first job in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
Hi mate, fresh out of PTS I bet you only have a 6mm and 10mm trowel. First of all if you are doing mosaics, get a smaller notch trowel! Second, TAKE YOUR TIME. Third use you grout float to press tiles into your adhesive (assuming they are on a sheet - what size mosaic?). Would use BAL White Star myself for addy though they do Mosaic-fix specially for this type of job, and BAL Microflex grout for kitchens.
Try to avoid small cuts around the edges if possible and only use the wet cutter where you can't avoid it - tiles come loose from the sheets!
CLEAN AS YOU GO ALONG!!!!!!!!!!!!!!!!!!!
Good luck, let us know how you get on.
Grumpy
F
Fekin
Main bit of advise I can think of giving for tiling mosaics is watch adhesive amounts, excess will seep through the mosaic netting and fill up your grout lines fast, so just keep an eye out for that.
Also depending on mosaic tile size, there are a lot of grout lines and they will eat up a large amount of it, work cleanly.
Reply to first job in the British & UK Tiling Forum area at TilersForums.com
Hello everyone, My names Fraser I have been in the motor trade for 17 years, after falling out...
I’m halfway through tiling a shower cubicle at home. First time doing any tiling. I’ve used...
DIY Tiling; Advice for DIY Tilers So long story short, I have just purchased my first house and...
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
first job
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
