Discuss first time self leveling in the British & UK Tiling Forum area at TilersForums.com.
spudgun
hi guys
used bal multibase today for the first time, just a few questions
1.what kind of consistency should i have been looking for
2.what area should i be working at one time
3.what is the best way to level it out ,i was using a battern
the reason i ask is found it hard to get a good finish ,and guess it is me not the product,this is the first time i have used any self level ,by the way
grumpygrouter
It is not necessarily you Spudgun. SLC is not the easiest stuff to use by any means. I tend to smooth with a plasterers feather if room allows. If not, I use a piece of "L" section steel I got from B&Q. I find if you mix in accordance with the bag instructions (bal multibase, i must clarify) then it is a wee bit too thick, so I tend to thin it slightly with a tad more water.
DHTiling
This is one i am using a lot at the moment...
Water-bored ultra-fast hardening self levelling fibre reinforced smoothing compound.
Applications:
Fiberplan is used for smoothing and levelling from 3 to 10 mm over adequately anchored wood substrates and wooden boarding where good resistance to loads and traffic is required; Fiberplan is suitable for wheeled chair traffic and for heated floors.
Fiberplan can only be used internally.
Smoothing of old and new timber floors: wooden boarding, chip-board panels, plywood, parquet.
Smoothing cement, terrazzo, old ceramic tile, natural stone substrates. Coverage
1.6 kg/m2 per mm of thickness. Packaging
25 kg bags.
grumpygrouter
With BAL, you only get about 25mins in the bucket so you can't mix up a full bag anyway (well, I don't) so really you are only doing couple of m2 at a time. I start out using a trowel to spread and smooth and then run over the top with a straight edge. I find that you get accululations on the straight edge which, if you go back over leaves deposits where you have already smoothed so you have to start smoothing again with a clean edge.
Spud
self leveling spiked rollers etc are only going to get the air bubbles out of the levelling compound ,they help on thin coats of leveller but once it starts getting deeper they dont help imo.to get a level flat flat floor you need to have the area done in one hit and you need alot of material , 25 kg bag per sq m is what i normally estimate on floors ,if you put only 3-5mm of material down all you will achieve is that you will follow the existing contours of the floor and have to pack it out anyway, it takes alot of practice to get good at laytexing the best one i have used is the webber nivdur range( i am not a fan of any of the other webber products)the rest are pretty much the same ,water based levellers seem to be slightly better than the two part ones in my opinion
Reply to first time self leveling in the British & UK Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
Hi guys, had some great advice here before so thought I would ask here for advice again...
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
