Hi,
I am in the process of fitting a wet room but the wall is out of plumb and the floor is sloping slighty i leveled floor as much as i could with shims prior to boarding
Now its all tiled the shower screen has arrived which is a 1850 tall x 1000 wide glass panel which has a inch roughly deep channel which fixes to the wall and the panel fits onto and is screwed through usual way but because the floor runs slighty down and the wall is not plumb when the panel is sat on the floor it touches on bottom corner but is about 1 1/2 away from wall at top so no good to fix through,
Is there anywhere you can buy a deeper channel from?
