Discuss Fitting BCT 400 * 250 walls tiles to plasterboard and plaster in the UK Tiling Forum area at TilersForums.com.
TerryTibbs
Hi Guys,
I'm doing a job for a friend in a few weeks using BCT 400 x 250 White ceramic tiles in a bathroom with a bathtub with a shower above it.
I'll be doing about 12sqm including a mosaic border.
The surface will be Fresh plasterboard and old plaster (cement).
Do I need to use any sort of backing board infront of the plaster/board or should I use moisture resistant boards?
I have a few tubs of ready mix adhesive that was left over from a big job on site...can I use this?
What trowel should I use? 4mm? 6mm notch or rounded?
Greatful for any advice.
Rookery
As above, waterproof the wet areas (ie around the shower area) with a tanking kit such as Mapei Shower Kit. You could use a ready mixed adhesive but in view of the size of the tile, you would have to leave grouting for several days to ensure adhesive had dried properly. Better to use a cement based one such as Mapei Adesilex P9. You have to mix it with water but it stays workable in the bucket for virtually a whole day and I find its easier to trowel out than ready mixed. You'll have to prime the walls first with a proper tilers primer such as Mapei Primer G. With that size of tile I'd use an 8mm notch minimum.
Reply to Fitting BCT 400 * 250 walls tiles to plasterboard and plaster in the UK Tiling Forum area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
    Votes: 5 4.7%
    Votes: 8 7.5%
    Votes: 6 5.6%
    Votes: 29 27.1%
    Votes: 14 13.1%
    Votes: 27 25.2%
    Votes: 3 2.8%
    Votes: 2 1.9%
    Votes: 19 17.8%
    Votes: 18 16.8%
    Votes: 13 12.1%
    Votes: 5 4.7%
    Votes: 3 2.8%
    Votes: 1 0.9%
