Discuss Fitting Mosaic Tiles in the British & UK Tiling Forum area at TilersForums.com.
Sean fsy
if the mosaics are paper backed you will only get one chance in fitting them as they will just fall apart if trying to remove again. as said pat on with a grout float. using spacers some time are no help as they will just want to collapse on them selves. i find a packet of panel pins or similar come in handy just to take the weight of the sheets just tap a couple in at the top of a sheet. also dont try to cut paper back mosaics with a wet cutter as they just fall aprt, the best way if the tiles allow is to use a splitter cutter with a deep rubber spacer attatched and split them individually.
Reply to Fitting Mosaic Tiles in the British & UK Tiling Forum area at TilersForums.com
Hi there. I recently tiled a shower floor with a basalt mosaic tile. I used kerapoxy for the...
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
